Kända problem med Samba och Mint 19
Inläggav Mikael » fre maj 03, 2019 8:10 pm
..tycks det vara, om jag tolkat rätt från bloggen:
Samba
With every new package base we experience regressions. This was key in our decision to stick to LTS and it helped us focus on development while underneath, the base we were using for 5 years could continue to mature. This decision boosted our development pace and increased the quality of our distribution. When with Linux Mint 19 we jumped to Ubuntu 18.04, along with the many improvements and new software versions, we also inherited regressions, some of them quite frustrating to users: Wine, scanner and printer, and Samba to name a few.
These kind of issues are common on new package bases and they happen often in rolling distributions or in non-LTS releases. They eventually get fixed, in these rolling distributions and non-LTS releases first and then the fix usually gets backported to the LTS base.
This hasn’t happened with Samba yet. When something important we don’t maintain doesn’t work properly, and it’s been a while, we usually consider pinning it. In other words we look at whether or not we can backport a newer version which fixes the issue, or bring back an earlier version which didn’t suffer the issue. In the case of Samba this is not possible, not only because of Samba’s complexity and large number of dependencies (it just doesn’t easily compile like that across bases) but also because pinning this package in Mint would be a maintenance issue due to the number of vulnerabilities found in Samba and how often it receives security updates.
Samba supports different communication protocol versions. In Mint 18.x Samba 4.3 was mostly using a protocol version called NT1 which worked well and continues to work well. After Windows was badly affected by ransomware attacks, Microsoft decided to retire NT1 and the Samba team worked on switching more towards some of the newer protocol versions such as SMB2 and SMB3. These changes created regressions and Ubuntu is currently in the process of trying to tackle them.
https://blog.linuxmint.com/?p=3742
Kan ju vara bra att ha i åtanke om det är något som jæ\/£@$...
Linux Mint 20.3 Una, Cinnamon @Mintbox Mini2 Pro      "from freedom came elegance"
