Mint 12 och WiFi
Mint 12 och WiFi
Inläggav Mikael » sön feb 05, 2012 1:07 pm
Har på en bärbar installerat 12 KDE.
Det går att ansluta sig via trådlöst nätverk men sedan är det i princip stopp. Hastigheten är urusel eller sämre, alltså så dålig att man inte kan nyttja detta alls.
Googlade lite och hittade:
http://www.intel.com/support/wireless/sb/cs-006408.htm
som ger denna:
http://www.intellinuxwireless.org/
som ger denna:
http://www.intellinuxwireless.org/?p=iwlwifi
som ger denna:
http://www.intellinuxwireless.org/?n=downloads
Där tankar jag hem:
http://www.intellinuxwireless.org/iwlwi ... 1.2.24.tgz
För mitt kort 4965AGN
I readme, under installation så står:
2. INSTALLATION
The iwlwifi-4965 driver will look for the file iwlwifi-4965-2.ucode using the kernel's firmware_loader infrastructure. In order to function correctly, you need to have this support enabled in your kernel. When you configure the kernel, you can find this option in the following location:
Device Drivers ->
Generic Driver Options ->
Hotplug firmware loading support
You can determine if your kernel currently has firmware loader support by looking for the CONFIG_FW_LOADER definition on your kernel's .config.
In addition to having the firmware_loader support in your kernel, you must also have a working hotplug and udev infrastructure configured.
The steps for installing and configuring hotplug and udev are very distribution specific.
Once you have the firmware loader in place (or if you aren't sure and you just want to try things to see if it works), you need to install the microcode file into the appropriate location.
Where that appropriate location is depends (again) on your system distribution. You can typically find this location by looking in the hotplug configuration file for your distro:
% grep \"^FIRMWARE_DIR\" /etc/hotplug/firmware.agent
This should give you output like:
FIRMWARE_DIR=/lib/firmware
If it lists more than one directory, you only need to put the microcode in one of them. In the above example, installation is simply:
% cp iwlwifi-4965-2.ucode /lib/firmware
You can now load the driver (see the INSTALL and README.iwlwifi provided with the iwlwifi package for information on building and using that driver.)
Klartext tack :shock:
Vad behöver jag göra till 12,an? Bara köra % cp iwlwifi-4965-2.ucode /lib/firmware ?
Jo, jag har vid sidan om även installerat12 Gnome - samma förfarande där?
Re: Mint 12 och WiFi
Inläggav tux-sven » sön feb 05, 2012 2:20 pm
Det verkar vara ett gammalt problem. Emellertid tycks det funka helt ok för en del.
http://forums.linuxmint.com/viewtopic.php?f=49&t=12048
Det går inte att ställa om 802.11 till b eller g i routern? :roll:
Inläggav Mikael » sön feb 05, 2012 5:11 pm
Jo, jag skulle kunna testa med g men tycker väl att det är onödigt.
Men vad menar man eg. med readme,n i mitt förra inlägg?
Inläggav tux-sven » sön feb 05, 2012 5:34 pm
Jo men jag ser det så här:
Din wifi går tydligen igång trots allt, men den kommunicerar dåligt.
Alltså finns troligen rätt drivrutin redan installerad - annars hade du inte fått någon kontakt alls.
Men tydligen "pratar" inte routern och wifi kretsen samma språk riktig, därför blir kommunikationen dålig.
I slutet på länken som jag hänvisar till står det att drivern för 4965AGN bara funkar för 802.11 till b eller g i Linux. Nog borde det väl vara värt ett försök.
För OM det skulle vara på det viset - så spelar det ingen roll hur du trixar men drivern för 4965AGN, du kommer inte att få det att fungera ändå.
Dessutom står det att det har fungerat utan problem för en del personer - med samma programvara och Linux. Men de har nog olika WiFi-modem.. ;)
Mvh,
Inläggav Mikael » sön feb 05, 2012 6:28 pm
Aha, då är jag med i resonemanget.
Och visst - med g så funkar allt bra..
Tack!
Inläggav tux-sven » sön feb 05, 2012 8:35 pm
