XRDP
XRDP
Inläggav LasseTö » tor apr 09, 2026 8:06 pm
jag försöker köra RDP från en Win 11 maskin mot en NUC med Linux Mint & XRDP installerat.
Jag kommer fram till inloggningsrutan på Linux Mint, men kan f.n inte komma på hur jag ska logga in. Vad jag än använder som användarnamn / lösenord så får jag att connection är ok men att login failed
Ska man kvalificera användarnamnet med nånting.
LasseTö
Re: XRDP
Inläggav LasseTö » tor apr 09, 2026 9:13 pm
Jag har luskat vidare & tror att det har nåt med tangentbords layouten att göra:
lasset@LasseT-Linux:~$ sudo tail -f /var/log/xrdp.log
[sudo] lösenord för lasset:
[20260409-21:20:01] [INFO ] xrdp_caps_process_codecs: nscodec, codec id 1, properties len 3
[20260409-21:20:01] [WARN ] xrdp_caps_process_codecs: unknown codec id 5
[20260409-21:20:01] [INFO ] Loading keymap file /etc/xrdp/km-0000041d.ini
[20260409-21:20:01] [WARN ] local keymap file for 0x0000041d found and doesn't match built in keymap, using local keymap file
[20260409-21:20:18] [INFO ] connecting to sesman on 127.0.0.1:3350
[20260409-21:20:18] [INFO ] xrdp_wm_log_msg: sesman connect ok
[20260409-21:20:18] [INFO ] sesman connect ok
[20260409-21:20:18] [INFO ] sending login info to session manager. Please wait...
[20260409-21:20:19] [INFO ] xrdp_wm_log_msg: login failed for user LasseT
[20260409-21:20:19] [INFO ] login failed for user LasseT
lasset@LasseT-Linux:~$ sudo tail -f /var/log/xrdp-sesman.log
[20260409-21:19:21] [INFO ] AUTHFAIL: user=LasseT ip=fe80::30e1:93fb:ff58:3f6c time=1775762361
[20260409-21:19:21] [ERROR] sesman_data_in: scp_process_msg failed
[20260409-21:19:21] [ERROR] sesman_main_loop: trans_check_wait_objs failed, removing trans
[20260409-21:19:37] [INFO ] sesman_main_loop: sesman asked to terminate
[20260409-21:19:53] [INFO ] starting xrdp-sesman with pid 894
[20260409-21:20:18] [INFO ] Socket 12: AF_INET6 connection received from ::1 port 41138
[20260409-21:20:19] [ERROR] pam_authenticate failed: Authentication failure
[20260409-21:20:19] [INFO ] AUTHFAIL: user=LasseT ip=::ffff:192.168.0.117 time=1775762419
[20260409-21:20:19] [ERROR] sesman_data_in: scp_process_msg failed
[20260409-21:20:19] [ERROR] sesman_main_loop: trans_check_wait_objs failed, removing trans
lasset@LasseT-Linux:~$ sudo tail -f /var/log/Xorg.10.log
tail: kan inte öppna '/var/log/Xorg.10.log' för läsning: Filen eller katalogen finns inte
tail: inga fler filer
När jag kollar vilken layout som används får jag detta svar:
asset@LasseT-Linux:~$ setxkbmap -query
rules: evdev
model: pc105
layout: se,us
variant: ,
options: terminate:ctrl_alt_bksp
Är det korrekt?
Om inte vad ska då göras?
LasseTö
Re: XRDP
Inläggav Jan-Olof » lör apr 11, 2026 2:47 pm
Välkommen!
jan-olof@hemmabygget:~$ setxkbmap -query
rules:      evdev
model:      pc105
layout:     se
options:    grp:win_space_toggle,terminate:ctrl_alt_bksp
Du verkar ha lagt in stöd för två teckenuppsättningar men om se är standard så borde den delen fungera, tycker jag.
