Linux Mint 22 - Wilma
Re: Linux Mint 22 - Wilma
Inläggav bittin » tis aug 06, 2024 7:03 am
Inläggav bosse » ons aug 07, 2024 6:35 am
Kan följande system "orka med" Wilma ?
Inläggav bittin » tor aug 08, 2024 3:34 am
Inläggav bittin » tor aug 08, 2024 3:50 am
bosse skrev:Kan följande system "orka med" Wilma ?
System requirements:
2GB RAM (4GB recommended for a comfortable usage).
20GB of disk space (100GB recommended).
1024×768 resolution (on lower resolutions, press ALT to drag windows with the mouse if they don’t fit in the screen).
https://blog.linuxmint.com/?p=4731
2 GHz dual-core processor
4096 MiB RAM (system memory) for physical installs.
2048 MiB RAM for virtualised installs.
25 GB (8.6 GB for minimal) of hard-drive space (or USB stick, memory card or external drive but see LiveCD for an alternative approach)
3D acceleration-capable GPU with at least 256 MB of VRAM
1024x768 or higher resolution display
USB flash drive or DVD drive or for the installer media
Internet access is helpful
https://help.ubuntu.com/community/Insta ... quirements
så det borde fungera
Inläggav bosse » tor aug 08, 2024 5:02 am
Tackar för detta, verkar hoppfullt :)
Inläggav bittin » fre aug 09, 2024 4:19 pm
Inläggav Mikael » sön aug 11, 2024 1:43 pm
Distrowatch:
https://distrowatch.com/weekly.php?issue=20240805#mint
There is a reason, several reasons, I usually recommend Linux Mint to less experienced users and Linux newcomers. It is easy to install, offers five years of support, it's stable, and it is possible to perform virtually any task from the desktop without opening a command line. The system is unusually friendly, integrated across components, and it's pleasantly straight forward to install software across multiple formats. It's also consistent. While some mainstream distributions publish a mixture of good and bad releases, Mint has steadily published good, polished releases for over a decade that have delivered a friendly, stable experience. I'd recommend it for both beginners and more experienced users who want to spend more time using their computer than setting it up.
Inläggav Jan-Olof » sön aug 11, 2024 6:07 pm
...med andra ord (DeepL med lite efterredigering):
Det finns en anledning, rent av flera, till att jag brukar rekommendera Linux Mint till mindre erfarna användare och Linux-nykomlingar: Det är enkelt att installera, erbjuder fem års support, det är stabilt och det är möjligt att utföra praktiskt taget alla uppgifter från skrivbordet utan att öppna ett kommandofönster. Systemet är ovanligt användarvänligt, de olika komponenterna är väl integrerade och det är behagligt enkelt att installera programvara i olika format. Det är också konsekvent. Medan vissa vanliga distributioner publicerar en blandning av bra och dåliga utgåvor har Mint alltid publicerat bra, polerade utgåvor i över ett decennium och har levererat en användarvänlig, stabil upplevelse. Jag skulle rekommendera det för både nybörjare och mer erfarna användare som vill spendera mer tid på att använda sin dator än att konfigurera den.
Inläggav bittin » tor aug 15, 2024 5:07 am
Ännu ett avsnitt av Mintcast från Lördag-Söndag förra veckan är nu uppladdat: https://mintcast.org/443-5-mint-22-any-thoughts/ dom babblar i 1-2 timmar om vad dom tycker om nya Linux Mint 22 nu då det har vart ute i några veckor och dom har testat
Inläggav bosse » tor aug 15, 2024 4:11 pm
Funkar bra! :D
Inläggav Osprey » fre aug 16, 2024 3:48 pm
Funkar inte bra... Menylisten i LXDE blir för kort och lämnar ett utrymme efter sig. "Knapparna" för befintliga program skalar sig inte heller och har låst storlek...
Inläggav Marie SWE » lör aug 17, 2024 3:14 am
Mint22 fick både ros och beröm... samt utvecklarna fick lite kritik av LearnLinuxTV
Då utvecklarna klagar på Ubuntu och snap.. Men istället för att gå över till LMDE och satsa där som de redan har uppe o funkar, så fortsätter de på Ubuntu basen och klagar på Ubuntu. :roll:
8minuter lång: Linux Mint 22 Cinnamon Review - New Ubuntu Base, Same Mint
https://www.youtube.com/watch?v=eDwjqBc7M4w
Han nämnde även LMDE6 i videon. :)
Inläggav bittin » lör aug 17, 2024 7:58 am
Blir att test uppdatera på jobbet i September-Oktober då jag är tillbaka från sommarsemestern
Inläggav bittin » tor aug 22, 2024 11:55 am
bittin skrev:Blir att test uppdatera på jobbet i September-Oktober då jag är tillbaka från sommarsemestern
Detta blir Fredagens och Måndagens jobb
hemifrån och på kontoret
Inläggav bittin » fre aug 23, 2024 7:05 am
Ännu en Youtube recension av nya Linux Mint 22: https://www.youtube.com/watch?v=k44u9qjPdUw
Användare som besöker denna kategori: Inga registrerade användare och 31 gäster
