skärmupplösning Löst
Re: skärmupplösning
Inläggav bosse » ons aug 13, 2014 8:57 am
bo@bo-DIXONSXP ~ $ sudo lspci -vk
[sudo] password for bo:
00:00.0 Host bridge: Silicon Integrated Systems [SiS] 671MX
Subsystem: Elitegroup Computer Systems Device 5050
Flags: bus master, medium devsel, latency 32
Memory at d0000000 (32-bit, non-prefetchable) [size=64M]
Capabilities: [c0] AGP version 3.5
Kernel driver in use: agpgart-sis
00:01.0 PCI bridge: Silicon Integrated Systems [SiS] AGP Port (virtual PCI-to-PCI bridge) (prog-if 00 [Normal decode])
Flags: bus master, 66MHz, fast devsel, latency 0
Bus: primary=00, secondary=01, subordinate=01, sec-latency=0
I/O behind bridge: 00009000-00009fff
Memory behind bridge: d4000000-d40fffff
Prefetchable memory behind bridge: c0000000-cfffffff
00:02.0 ISA bridge: Silicon Integrated Systems [SiS] SiS968 [MuTIOL Media IO] (rev 01)
Subsystem: Elitegroup Computer Systems Device 5a00
Flags: bus master, medium devsel, latency 0
00:02.5 IDE interface: Silicon Integrated Systems [SiS] 5513 IDE Controller (rev 01) (prog-if 80 [Master])
Flags: bus master, medium devsel, latency 128, IRQ 16
I/O ports at 01f0 [size=8]
I/O ports at 03f4
I/O ports at 0170 [size=8]
I/O ports at 0374
I/O ports at 1080 [size=16]
Capabilities: [58] Power Management version 2
Kernel driver in use: pata_sis
00:03.0 USB controller: Silicon Integrated Systems [SiS] USB 1.1 Controller (rev 0f) (prog-if 10 [OHCI])
Flags: bus master, medium devsel, latency 32, IRQ 20
Memory at d4104000 (32-bit, non-prefetchable) [size=4K]
Kernel driver in use: ohci-pci
00:03.1 USB controller: Silicon Integrated Systems [SiS] USB 1.1 Controller (rev 0f) (prog-if 10 [OHCI])
Flags: bus master, medium devsel, latency 32, IRQ 21
Memory at d4105000 (32-bit, non-prefetchable) [size=4K]
00:03.3 USB controller: Silicon Integrated Systems [SiS] USB 2.0 Controller (prog-if 20 [EHCI])
Flags: bus master, medium devsel, latency 32, IRQ 22
Memory at d4106000 (32-bit, non-prefetchable) [size=4K]
Capabilities: [50] Power Management version 2
Kernel driver in use: ehci-pci
00:04.0 Ethernet controller: Silicon Integrated Systems [SiS] 191 Gigabit Ethernet Adapter (rev 02)
Flags: bus master, medium devsel, latency 0, IRQ 19
Memory at d4307000 (32-bit, non-prefetchable) [size=128]
I/O ports at 1000 [size=128]
Capabilities: [40] Power Management version 2
Kernel driver in use: sis190
00:05.0 IDE interface: Silicon Integrated Systems [SiS] SATA Controller / IDE mode (rev 03) (prog-if 8f [Master SecP SecO PriP PriO])
Subsystem: Silicon Integrated Systems [SiS] SATA Controller / IDE mode
Flags: bus master, medium devsel, latency 32, IRQ 17
I/O ports at 10c8 [size=8]
I/O ports at 10bc [size=4]
I/O ports at 10c0 [size=8]
I/O ports at 10b8 [size=4]
I/O ports at 10a0 [size=16]
Kernel driver in use: sata_sis
00:0f.0 Audio device: Silicon Integrated Systems [SiS] Azalia Audio Controller
Flags: bus master, medium devsel, latency 0, IRQ 18
Memory at d4100000 (32-bit, non-prefetchable) [size=16K]
Kernel driver in use: snd_hda_intel
01:00.0 VGA compatible controller: Silicon Integrated Systems [SiS] 771/671 PCIE VGA Display Adapter (rev 10) (prog-if 00 [VGA controller])
Flags: 66MHz, medium devsel, IRQ 9
BIST result: 00
Memory at c0000000 (32-bit, prefetchable) [size=256M]
Memory at d4000000 (32-bit, non-prefetchable) [size=128K]
I/O ports at 9000 [size=128]
Expansion ROM at <unassigned> [disabled]
Capabilities: [50] AGP version 3.0
Svaret på min fråga: sudo lspci -vk Kan kanske vara till någon hjälp? ser att kernel in use saknas vga:n
Re: skärmupplösning
Inläggav Mikael » ons aug 13, 2014 7:35 pm
stickanbj skrev:Kan detta vara något???
http://www.socialphy.com/posts/computer ... Linux.html
kanske,men jag lyckas inte få till det. Beror nog mest på mig. :)
Men var tar det så att säga stopp?
Re: skärmupplösning
Inläggav mattem » ons aug 13, 2014 7:52 pm
bosse skrev:Hej
Helt ny med Linux,har dock provat olika varianter: ubuntu, kbuntu, debian och nu Mint.
Skärmupplösningen har jag problem med, den visar enbart 640x480, 800x600.
Jag skulle vilja komma lite högre,1024x768 tex
SIS mirage3 kort, Intel celeron530 1,73Ghz, 120Gb disk
har installerat linuxmint-9-gnome-cd-i386.iso
Tacksam för hjälp
Av det jag kan utläsa så handlar det om rejält gammal hårdvara och gissningsvis så saknas stöd för bland annat grafikkortet i nyare distar. Så t ex en äldre version av Mint är kanske inte fel tänkt.
Nästa problem är att S3 var en marginell tillverkare jämfört med AMD/nVidia även om det var ett populärt budget-chip på den tiden den datorn var ny. Det bästa du kan göra är troligtvis att hitta ett bättre begagnat grafikkort med nVidia eller AMD-chipp. Att hitta stöd för S3-kortet är antagligen ett hopplöst projekt.
Re: skärmupplösning
Inläggav bosse » ons aug 13, 2014 7:55 pm
Skrev av kommandona som jag läste på laptopen bredvid linuxmaskinen,jag skall försöka att klippa o klistra av kommandona i linuxmaskinen istället. Kanske funkar bättre?! Slipper möjliga felavskrifter.?
Re: skärmupplösning
Inläggav Jan-Olof » tor aug 14, 2014 12:05 am
Mikael skrev:Hittade detta:
http://unix.stackexchange.com/questions ... -processor
Jan-Olof kanske kan ta en titt där och se om det verkar relevant?
Sidan handlar ju om videoacceleration men löser inte problemet vad jag kan se.
bosse skrev:Under installationen är upplösningen OK, efter omstart av systemet är upplösningen 640x480
Om det blir rätt under installationen så borde det kunna fungera även efteråt. Finns det inga fler upplösningar att välja? Vad får du för svar om du öppnar ett terminalfönster och klistrar in följande kommando?
xrandr -q
mattem skrev:...gissningsvis så saknas stöd för bland annat grafikkortet i nyare distar. Så t ex en äldre version av Mint är kanske inte fel tänkt.
Någon skrev i ett inlägg att det finns stöd för det kortet i Mint 13 Cinnamon. Den versionen har ju fortfarande support så det kan vara värt att prova om inget annat går.
bosse skrev:Skrev av kommandona som jag läste på laptopen bredvid linuxmaskinen,jag skall försöka att klippa o klistra av kommandona i linuxmaskinen istället.
Markera genom att hålla ner vänster musknapp och dra, högerklicka och kopiera.
Re: skärmupplösning
Inläggav stickanbj » tor aug 14, 2014 2:32 pm
Det finns ytterligare en väg att gå. Installera paketet ALIEN (finns i paketförrådet) och ladda ner RPM-paketet från RPM-find eller rpm.pbone.net. Alien kan hantera installation av rpm-paket i Mint.
Re: skärmupplösning
Inläggav bosse » tor aug 14, 2014 3:00 pm
xrandr -q
bo@bo-DIXONSXP ~ $ xrandr -q
xrandr: Failed to get size of gamma for output default
Screen 0: minimum 640 x 480, current 640 x 480, maximum 640 x 480
default connected 640x480+0+0 0mm x 0mm
640x480 73.0*
Re: skärmupplösning
Inläggav bosse » tor aug 14, 2014 3:13 pm
stickanbj skrev:Det finns ytterligare en väg att gå. Installera paketet ALIEN (finns i paketförrådet) och ladda ner RPM-paketet från RPM-find eller rpm.pbone.net. Alien kan hantera installation av rpm-paket i Mint.
Det finns "hur många som helst" varianter på RPM-find sidan, som novis undrar jag vad som är relevant i sammanhanget. :) :?:
Re: skärmupplösning
Inläggav bosse » tor aug 14, 2014 3:24 pm
Mikael, på din fråga vad det tar stopp så kommer jag hit:
bo@bo-DIXONSXP ~ $ lspci | grep -i vga
bo@bo-DIXONSXP ~ $ sudo apt-get install gcc make binutils kernel-devel git xorg-dev mesa-common-dev libdrm-dev libtool
Läser paketlistor... Färdig
Bygger beroendeträd
Läser tillståndsinformation... Färdig
E: Kunde inte hitta paketet kernel-devel
bo@bo-DIXONSXP ~ $
Re: skärmupplösning
Inläggav bosse » fre aug 15, 2014 8:59 am
Tack till alla som engagerat sig i mitt problem!! Jag har installerat LinuxMint 13 Cinnamon, och nu funkar det!!
Nu återstår det att sätta sig in i Linuxvärlden, skall bli ett sant nöje!
Återigen, tack för all hjälp. Jag får kanske anledning att återkomma. :D
Re: skärmupplösning
Inläggav mattem » fre aug 15, 2014 11:42 pm
Vad kul att du löste problemet :D
Re: skärmupplösning
Inläggav bosse » lör aug 16, 2014 8:26 am
mattem skrev:Vad kul att du löste problemet :D
Jag??
